xXCiviXx
Not when said person has a great disdain for red and blue as a combination
	I hear you man. I'm eyeballing the Enkei GTC01s.The white ones in 18x8 are on sale for $389 a piece at Tire Rack right now. A bit more than I would prefer to spend, but between them being white and only weighing 17.4lbs, I am willing to spend a bit more.
Awesome build! Looking forward to seeing more of your build!
Michelin PSS 17s don't come in a 40.235/40 or 245/40 would fit best.
I know the spedometer will be a little off, but a 245 seems like it would be a bit too wide for an 8" wide wheel.245/40 might be available.
The 235/40 is hard to find in many tire brands. And 235/45 is a size that normally goes on a TL which is a larger tire diameter than stock. There will be rubbing and inaccurate speedometer reading.
Fit and how they look are two completely different things.Not really. I'm looking to get the 17*8 enkei gtc01 with 245/40/17 tires. 235/40/17 can fit the stock 17*7. Lol.
Hey Dar... just curious because that's a difference between stock and I can't see anything abnormal in the looks. Don't they stick out at all? How's the difference in the driving? What brand you end up choosing? Have a good day Dar and speak soon.It's doable. The tires aren't pinched. Here is what a set of 245/40/17 Toyo RA01 looks like on 17x8 RPF1s.
This is what the Super Sports look like on a 17x8 OZ Racing Alleggerita.Was just reading that PSSs also run wide...so a 235 will be closer to a 245. Makes me wonder if I should just get a 225 since they run wide.
	The setup is just wider tires/wheels for an improvement in acceleration/braking/handling. It really just depends on the wheel offset for the setup to stick out. I still am planning on getting Michelin Super Sports in 245/40/17 with 17x8 light weight wheels. I still have a lot of time to think about the offset or even the wheel brand (Enkei GTC01 is my top choice right now) since I will be making a purchase by the end of April or May.
http://forums.vwvortex.com/showthre...5b1d936cbd&p=73221933&viewfull=1#post73221933
Aren't you planning on getting the same exact wheels? Alleggeritas?Alright, I am sold. That doesn't look bad at all. 17x8 with a 245/40/17 it will be.
