OmarGarcia
I was wondering if putting on 25mm spacers on my civic si would poke it out too much? I'm looking to be flush with the sides. I don't want it to look dumb.
thanks guys for the input.
Here's my setup on 20mm spacers 225 45 as well.. Sportline springs too. I had to roll fenders and just to let you know, the sedans body I just a hair wider than the coupes they're could be significant rub without getting fender work done. I'm also at oem specs on my alignment. Might be a good idea to test fit because you might be getting into some trouble considering you have wider tires and your lowered
on stock wheels... stock suspension?
reference pics -
http://9thcivic.com/forum/threads/time-for-a-thread-13-tw-sedan.8048/page-3#post-203714
15mm front spacers
20mm rear spacers
that isn't my car, but you use the studs off the spacer to mount the wheel. The oem studs hold the new spacers to the car wheel with bolts.I know this was a while ago but I'm considering 20mm spacers.. Did you have to get extended studs or with 20mm you don't have to?
