hwasa
Awesome build! Do like the drive height as well. No rubbing or anything without camber arms? Good deal
I might need them for my '14 coupe though because of 18s
No rubbing at all, and the drive is great only real complain is that the front right hand shock makes a loud bang sound if I go over a small bump. But that might be the shocks not the spring. Other then that worth every penny. Height is perfect IMO.Awesome build! Do like the drive height as well. No rubbing or anything without camber arms? Good dealI might need them for my '14 coupe though because of 18s
Did you put the bump stop in?No rubbing at all, and the drive is great only real complain is that the front right hand shock makes a loud bang sound if I go over a small bump. But that might be the shocks not the spring. Other then that worth every penny. Height is perfect IMO.
YessirDid you put the bump stop in?
Thanks, I like em a lot!I forgot to do it once on my s2000 and it made the same noise. Those skunk 2 springs look great![emoji106]
$500 for it lol. And no...way longer then that lolHow much? I've heard that the battery only last for 20 minutes.
they lost for a while lol at least 2-3 hours of filmingHow much? I've heard that the battery only last for 20 minutes.
I know, but I knew I was going to end up buying this camera so better now I guess.It's tempting, but for $100 more I can get a FlashPro.![]()
You can have the h11 ones I got. Pm meCan I have them?
Yes same ones in the pic above but h11Are they also arctic white?
70aThose are all great mods, what mount did you get 62a?
