View: http://youtu.be/zKpgAJCooXI
I just installed my AEM CAI this afternoon and it went pretty smoothly. I have a couple things I would like to note for other people who may buy this intake.
1. You do not have to trim any of the wheel well plastic like the instructions say. In fact, I feel it gives a lot more protection from water by not trimming the area. It will close right up just like it was stock so don't worry. The filter does sit just behind the fog lights and if you are in a wet area, I would strongly suggest purchasing the AEM 1-4000 Dry Flow Air Filter Wrap.
2. There is a spot where the intake tube could potentially cause a clanking noise during WOT. I fixed this by placing a small piece of foam 3M double sided tape on the tubing next to it.
3. The shifter bushings are easily accessed now. So in the future, if you upgrade them with some Hybrid Racing shifter bushings, you wont be forced to remove some of your intake to reach them.
4. This intake does not force you to relocate the battery or clutch lines. That was a huge deciding factor for me.
