- 10,234
- 6,954
- Vehicle Model
- Toyota Tacoma TRD Sport
- Body Style
- @bootyluvr hates hatches
Turned the right way, as in the shift pattern doesn't line up "properly"? Or you just can't screw it down the threaded shaft?
its screwed down all the way but when i get there its not turned the right way
Adjusted it where You want it and move the nut under the collar upward to tighten it hope it helps manI believe those were used with a lock nut but now looking at Speedy28 post above it should screw down the same as his Honda knob.
@speedy28 how did you get your shift knob to line up the shift pattern? Can you adjust the boot collar up and down? I have not messed with mine yet, so not sure.
Grafixpressions sells themAny good sources for extension pieces?
Love that boot. Why not a poke ball shift knob?
Don't get me wrong, I like the knob, looks awesomeBecause that's what everybody else would do. NeoChrome looks like a pokeball too, so I decided to go with that instead. It matches well in my opinion.
