falsettojonez
- 4
Trying to find or start a meet in the 845 area of Dutchess County NY.
Anyone in the area that wants to set something up lmk.
Hey man I'm looking for the same.....I'm in Middletown NY the wonderful 845Trying to find or start a meet in the 845 area of Dutchess County NY.
Front sway, rear sway, rear low tie bar, front low tie, upper strut bar and coiloverr. Still waiting on coilovers. Would do my self but no space to do it. Don't trust too many folks and most work must be done in my presence. My car is two weeks old and I plan to keep all stock parts
The upper is for bling. I just figured if O.E.M has front sway slightly bigger and adding the 22 would make them even. Thought I would keep front biggerThe front sway bar is absolutely unnecessary and will actually cause the handling to be worse. The upper strut bar will do no good whatsoever...unless you got it for bling factor.
Increasing the size on the front will just induce understeer. You actually want a bigger rear than stock to reduce the understeer and make the car turn better/tighter.The upper is for bling. I just figured if O.E.M has front sway slightly bigger and adding the 22 would make them even. Thought I would keep front bigger
