iShift_6
Thank you Sir....your solution is actually really nicely executed, never would have thought of doing it that way, i might see about building the SLC-712-DCVBR anyway
What did you do with your more too ones? I have seen a sale post on HIDplanet for $100 shipped. Think they are worth it? I currently have fusion fog retro with 5k bulb/hid kit. I am running into moisture issues and still need to create a system to adjust the height as they are pointing a bit high. The bulb on the pass side is hitting the washer fluid bottle which causes output issues since the bulb isn't sitting perfectly on the projector.@Nomar06 - You are correct on both fronts. It was an arm and a leg for them, but I bought them before the price went up even more.
However I did mistakenly buy the entire kit, so I got all the harnesses and the such. Not sure if you can buy just the housings.
And they do bolt right up, however adjusting them is a pain. Also there is a good deal of trimming to the rear of the fog housing.
But they do fit, and I like them more than the Morimoto ones that I had prior to this.
@webby - Thanks!!
you may like what he did with an acrylic rod -Oh...do you think our stock headlight have enough room to fit the new ILX led array with the lower drl and upper turn signal?
