the insider
Re: circuits staying alive after the car is shut off - depending what model civic you have and where one chooses to tap into the circuit one could be adding the accessory into the bcan network. For instance, if you have an Si, you may have noticed that you can turn the car off, yet the moonroof, power windows and accessory ambient light kit to name a few, stay alive with the key out until the driver's door is open and closed.
and make sure you're using each fuse slot on the tap in priority order of wiring
