Silver8th
- 14
Hey y'all so I just bought a 13 Civic Si and it didn't come with any key fobs it only has the spare key. Any suggestions? Has anyone had there car rechipped or re-keyed. Would it be a whole new immobilizer?
you can buy replacement keys though. Programming is a simple process -
(I should note that this would still be the process using the gray valet key, and then buying a fob like he has in the video. If you want the actual fob in the key itself, like the normal factory key, you'll have to get it programmed at a dealership to get the immobilizer to work. You can buy a blank key/keyfob for the car, but then the immobilizer will need programmed at a dealership, and that can run 75-150 dollars or so depending on the dealership)
View: https://www.youtube.com/watch?v=EQ49iKWbLXo
Hi!
I just got a new key fob for my 2014 civic lx and after trying multiple times I still can’t program it. I move my original key from off to on and click the lock button and repeat 4 times but I can’t make the lock system cycle and program the new key fob.
Any advice? Is the process different for a 2014 civic lx? Thanks!
Yes that is the key that I have. I bought a flip key that is supposed to come with the civic in japan so i was trying to set that one up.Doesn't your key have the lock/unlock on the key itself like the picture below? You say you're using the original key, but purchased a new fob?
Flip keys are an entirely different ball of wax. There wasn’t even a 9th generation civic in japan (so the seller lied, but anyway). Take a look through this thread. Just swapping your key guts over isn’t enough to get that key to work or even start the car.Yes that is the key that I have. I bought a flip key that is supposed to come with the civic in japan so i was trying to set that one up.
http://9thcivic.com/forum/threads/flip-key-thread-for-9th-gen.7863/
