Mikey miller
Active Member
- 4
- 0
Does anyone know if our 2k13 si can handle a 1000 watt amp and 1000rms subwoofer.? I have a memphis mojo 12 .
sure, wiring is all the same when you put in an amp in any car.
Looks like the amp is just for the subwoofer? If yes and if you have the premium audio, splice into the line before the factory amp and not after.
If you do not have a factory amp, then just tap to rear speakers like you would usually do when installing an amp. I think your subwoofer rms is 1500w...
The amp is only for the subwoofer being installed .my question is ; is the alternator gonna have enough power without killing battery or and alternator from a 1000 watt amp and a sub that powerfulwhat do you mean, "can it handle it"? Can the stock speakers handle it?
please read through this sticky postThe amp is only for the subwoofer being installed .my question is ; is the alternator gonna have enough power without killing battery or and alternator from a 1000 watt amp and a sub that powerful
Its own power source? I mean i have 4gauge wire kit for it and everything . i just meant will that be too much power for the car to handle. I wanna get a 600 or 1000 watt amp . the sub is 1000rms minimum and 2000 rms max
