George Tsimiklis
Member
- 38
- 7
Hi guys,
Here’s an update as of where I’m at now.
I took it Honda with the code wiped but the car idiling still rough etc...
Honda replies back to me the next day... did multiple tests with the car... flushed the ecu re learned idle and everything was fine. No problems....car was not idling funny and they took the car for a drive. they said If the problem came back that they said it is likely the 02 sensor...
So I am driving the car home and everything is pretty good. I decided half way home to stop by and get some gas and see if my problem would continue.
15$ supreme. Keep in mind there was no code when I had picked up the car. The moment I turned the car on, car started just fine. Check emission system back on...... also when I went to go above 3000rpm... I hit almost a flat spot. Hesitation... for a sec but than continued. now back at Honda... what the **** is going on with this thing?
mechanics said the intake had nothing to do with it,maybe it was a coincidence it happened when we changed the filter. They actually kept the short ram on.
So at this point I’m not sure if it’s really the 02 sensor or are they just going down the check list.
Hope you guys are all well
that's snap on is not made by Honda and may not have been used. More likely the tech is just guessing and has no idea what is wrong except its lunch time.
very cool. I wouldn't bring the car back to those idiots! Find A scotty Kilmer in your local area
