- 56,835
- 24,189
Cops/judge won’t care one bit about your car issues
change my mind on this, if that engine was a honda, it would have blown up a long time ago. SRT-4 has a racing engine mitsoFTFY
ff'sCops/judge won’t care one bit about your car issues
change my mind on this, if that engine was a honda, it would have blown up a long time ago. SRT-4 has a racing engine mitsoblock right from the factory- no four cyl car engine block has matched its strength-and never will
you're absolutely high as a kite.Honda often blow up when too much boost is added
This is simply not true,Cops/judge won’t care one bit about your car issues
weak. Get it up to 42 and then talkaround 15 pds of boost
go to 39 seconds. LS block, GSR crank.I would like to see the cars build list, a full racing engine block!
wanted to see how long it'd take to blow the motor.... 41.2psi on the stock block
View: https://www.youtube.com/watch?v=iOcqMOSvpRI
What are the specs on the LS block? Why is everything on a honda so secret?go to 39 seconds. LS block, GSR crank.
