I was watching jimmy o’s channel and he just got a cheap fixer upper S15. All he did was put rims on it and a new hood and the thing looks so hard. Those older nissans have really grown on me.
Yea I like his channel. He has so many cars he’s always puttin in work on.
Anyone else grind from 1st to 2nd in high rpm? Wondering if a k tuned master and slave would fix that.
driver mod needed.:bananawhipdance::cucumber::lildevil: thicker tranny oil might help a little. i don't think these trannys hold up at full throttle in 1, 2 second gear. Your also simply destroying your tranny doing holes shots:corngrin:don't put the power on when your in the middle of shifting, make sure its in gear all the way.
It’s not a diver issue when 3 generations of the car have the issue.
I’ve seen some vids/info on adjusting the play in the clutch pedal. The plunger/rod that pushes the fluid has some play where it actuates and also where it attaches to the pedal mechanism.
Cruising /r/justrolledintotheshop at work like
i adjusted that at the beginning of summer. i noticed a lot of play in the clutch pedal since i bought the car. still does it though, sounds awful.
When ever I do a job like this all I can think about is how techs in the southern states never have to deal with rust.
theres also a delay valve on the slave cylinder i think. The 6spd accords and TLs had one to reduce drivetrain shock, a lot of guys pulled them out, civic 6spd transmission shared a lot of parts to the accord/TL so maybe thats a factor too?
