- 57,293
- 24,309
Did you mean to say ps5 preorder
@Br3TT -
Lol @ 3080 fitting into the Ncase M1. Unless you can get your hands on a founders edition, you’re not gonna have a good selection of cards that fit in.
the evga 3080 xc3 ultra will fit no problem.....the ncase can support up to 317mm in length according to their site and i have seen people stuff some massive cards in this case@Br3TT -
It's not the size that I'd be concerned with. I wouldn't want the card exhausting into the case. That'll definitely bring up case temps.
I would upgrade the RAM and not working about the C18 timing. You're not going to get by with just 8 GB of RAM. I know I use 16GB DDR 3000 on a quad core i5 OC'd to 4.2 GHz from 2017 and can handle most loads with ease. You're running the minimum RAM for Forza. I would think you'd get a lot of improvement if you go with the larger load of RAM.
When you upgrade to the Ryzen 2600 you should get more than enough performance out of 3200 RAM, which would save you some money from the 3600 and your latencies will often be lower.
What do you mean it's "not a legit download"?
