Just kidding on the bitches part
Wake up you lazy bitches!Just kidding on the bitches part
Riiiiiiight, who you calling us bishes? You kumquat lint-licker !
I like removing lint from the dryer after the laundry is done lolLintI like removing lint from the dryer after the laundry is done lol
Hahaha. Me too!LintI like removing lint from the dryer after the laundry is done lol
Hey sorry for the late reply. DeathschWerks made custom fuel injectors for me. I called them and let them know I was running the RBC intake manifold. You can get them to either make it completely plug and play, get a plug kit or solder it just depends on your budget. But I am moving to the FIC injectors now since they are a much better injector.Did those drop right in, or did you have to use some kind of adapter? I just tried to install mine and they seem much too small for the manifold.
I had prl bore out my rbc to fit the 9th injectors.Hey sorry for the late reply. DeathschWerks made custom fuel injectors for me. I called them and let them know I was running the RBC intake manifold. You can get them to either make it completely plug and play, get a plug kit or solder it just depends on your budget. But I am moving to the FIC injectors now since they are a much better injector.
If you have the plastic R40 manifold you can get the adapter to compensate for the RBC injectors but you are pulling the injectors further from port making it harder to tune and not as consistent but absolutely possible. I ran the the adapter on my stock r40 manifold for a few months while I waited for my RBC kit and had absolutely no problems with Derek Robinson tuning my car.
All good! I have the 17u-00-0095-4 which appear to have been a universal application, and I'm on the CTE Manifold that comes with the Supercharger kit. The injectors seems a tad too small for the diameter of the bore, but I just shoved those hoes in there and torqued down the fuel rail. They seem pretty snug for now. Worst case scenario, the o-rings are a bit too compressed and will need to be replaced, but seems okay for now. I'll check it out in a few weeks to make sure it's okay and then at some point again later when I further upgrade the fueling system.Hey sorry for the late reply. DeathschWerks made custom fuel injectors for me. I called them and let them know I was running the RBC intake manifold. You can get them to either make it completely plug and play, get a plug kit or solder it just depends on your budget. But I am moving to the FIC injectors now since they are a much better injector.
Morning
