Janz3n
Well. Put my windows USB in. Booted to it. It started to load then rebooted in to windows just fine. Really confused.
I'm not sure what I'll do. Because it's my personal laptop my work may not pay for IT to fix it. My son is currently using my other laptop for online school ( yay canada ). One week to go. I may try swapping ssd or other things and see if it's hardware. For now I'll use the work laptop.
I forgot about win10...^
ill give that at try, also its my t520 , the x240 is the work laptop that was given after mine took a dump.I too thought this was your work laptop.
It's hard to say the cause, but the cheaper route would be to wipe the drive and start with a fresh OS install. If that doesn't work and the machine still freezes up on you afterward, then it's possible you have some sort of hardware issue.
If you haven't already, on a separate computer you can download the Windows Media Creation Tool to create yourself a current bootable USB drive with the latest version of Windows 10. From there, boot to that USB drive and click on "Install Now".
At the product key screen, select "I don't have a product key". You won't need the key since Microsoft will auto-activate a fresh install based on your previous license (licenses are tied to the motherboard, that's how they know).
Select the edition of Windows you previous had installed (Windows 10 Home or Windows 10 Pro).
Choose a custom install.
When it lists the partitions on the existing local drive, select each partition and then the "Delete" button to remove all the partitions, but be aware that this will blow away all the data on it so you may want to back up what you already have by slaving the drive onto another machine. If you have multiple disk drives in that laptop, they will be listed on this screen as "Drive 0", "Drive 1", etc, so you really only want to delete the partitions off of one drive, the one that the OS is installed on.
Once you've deleted all the partitions on the OS drive so that there is only a single listed drive with unallocated space, click the Next button to start the fresh install of Windows.
Once Windows is fully installed, go to the Lenovo X240 support page to install the latest drivers for that model.
It's hard to say if the drive is faulty or not, but performing a fresh install will surely tell you if the drive is even functional at this point. Plus this is the cheaper route than just going buy a new drive without knowing if it's faulty to begin with.
Hardly#Disappointed
I thought you know everything and don't forget![]()
speaking of windows, does anyone have feelings over the windows 11 leaks?
View: https://www.youtube.com/watch?v=hTceRqpgYOE
gov pc's on win 7 with no security/support in 18 months. Sounds about rightI haven't looked at any of the leaks. My work is still on Win7...Well not all of the PC's.
So can I pay you for a copy of said patchesShhh... We pay for the support/patches.
It's wild how much companies are willing to pay just to put off upgrading to Win10.
I was just messing with you. I’m still on vistaI don't have them. I'm just a desktop tech. I'm not involved in the patches/updates and such.
