RedShiftChris
Hi All,
Thought I would share my findings so far with the 9th gen Civic Si suspension I have recently inspected.
1) Camber plates: The front upper strut mount is identical between the 8th and 9th gen cars; so the ASR plates will work on 9th gen too.
2) Front struts:
- are very similar other than the swaybar tab and brake line brackets at the bottom.
- shock max and min length is about 1/4" longer (very similar); so the Koni insert length will work well. Koni insert fits perfectly in 2012 housing and is 1/4" shorter than the stock 2012 shock, which is fine for anyone wanting to lower the car.
- pin thread and length are the same. (pin is threaded part at top of shock piston)
- lower spring perch is approx 1/8" higher on the body (not too much different but looks slightly higher). perch stamping looks same as 8th gen Si perch.
- strut bearing is different and uses separate upper spring seat part number (not integral like on 8th civic), but the 8thcivic bearing (and integral spring seat) fits perfectly on 9th gen top hat (because the top hats are identical); so retrofits will be easy if needed. Interestingly, there are no bearings is the 9th gen strut bearing... it's some sort of plastic flat bearing and lube that has no moving parts other than the top moving relative to the bottom (and it's very thin and weighs almost nothing).
- the swaybar mounting tab on the 9th gen strut is going to make machining off the lower spring perch more difficult where needed, but it is still doable with manual removing of the spring perch first with a cutoff wheel and then finishing on the lathe.
- strut to upright "knuckle" bolts are larger on 9th gen car (8th was 14mm and 9th is 16mm).
3) Rear shocks
- rear shock is basically identical, and the Koni part will fit perfectly.
4) Rear spring
- the rear spring is slightly different from the 8th gen cars. The ID at the bottom is the same as 8th gen, but the top is not the same. Where the top ID of the 8th gen is significantly bigger then the bottom ID, on the 9th gen, the top is only very slightly bigger; so the upper mounting method must be slightly different. I need to see an actual 9th gen Civic in person before knowing the specifics of how a coilover will fit the back of the 9th gen.
- spring length appears to be the same; so current rear spring specs for coilovers should work the same on the 9th gen car.
And what does this all mean? It means that a drop spring kit for the 8th Civic does not fit the 9th Civic. It also means that a Koni based coilover kit for the 9th Civic is just a few relatively small changes from 8thCivic parts away from working perfectly. But I need a car to know for sure.
Anyone interested in making a 9th Civic available to me to look at. I can make it worth your while. Contact me asap.
Cheers,
Chris
2) Front struts:
3) Rear shocks
4) Rear spring
Cheers,
Chris
