Honda-Fan
Good morning, everyone
So if I get pulled over going 10 above I can tell the cop that hondafan said it was ok??After about 15 over, you're liable for a ticket, I think if it's another 10 or so above, you're liable for a felony. If you get sequential stops for the same behavior, you'll be suspended.
What's the usual max allowed to go over the speed limit in the states? Is it different in each state? I'm Ontario it's usually ok to go 18kmh over max speed limit on Ontario highways is 100kmh
In North Dakota the limit was 75, I was doing 82-84. Passed two cops doing 78. In Wisconsin think it was 70 but I was doing 85 and realized the next day that I was probably going too fast.
it's in idaho on the boarder of washington. spokane is just a little further westSay what now?
What he said.it's in idaho on the boarder of washington. spokane is just a little further west
Driving straight to jail!Yes, you'll get the go-ahead to keep driving.
LolololololDriving straight to jail!
I remember you had some noise back in the day with your actuator. Did you ever have it replaced back then?My Civic has developed a scraping sound like a chain slapping a cover during cold start. Has been that way for a bit. Took it into the mechanic.
Yeah…
Sounds like the VTEC actuator or one of the timing chain pulleys is bad causing the timing chain to hit the timing cover. Looking at $2k to make it stop.
2k??? Jesus. Do it yourself.My Civic has developed a scraping sound like a chain slapping a cover during cold start. Has been that way for a bit. Took it into the mechanic.
Yeah…
A couple hotels in the states did not have tea bags in the rooms. What's up with that?
I put it off and it’s just been getting worse. So, finally just going to get it all done and out of the way.I remember you had some noise back in the day with your actuator. Did you ever have it replaced back then?
https://9thcivic.com/forum/threads/...vtc-actuator-merged-threads.10167/post-433356
I have to ask what happens if you drink hot tea in a hotel?You drink hot tea in hotel rooms? No thanks... Ewww..
