Hondata Releases 2012 Honda Civic Si ECU Reflash!!
57,197
24,271
Hondata Releases 2012 Civic Si ECU Reflash!!
US 2012 Civic Si with K24Z7 engine (ECU part number 37820-RX0-A03 through RX0-A05)
Pricing
This reflash is specifically tuned for the USDM 2012+ Civic Si K24Z7.
K24Z7-Si ECU flash program 7600 rpm rev limit - $295
Hondata does not sell direct - all sales and payment must be conducted through Hondata dealers. The upgrade information form must be sent with your ECU.
Details
The K24Z7-Si program advances the ignition, alters the cam timing and optimizes the fuel adding 4-10 ft lb across the rev range and up to 20 hp on the top end.
2012 Civic Si
click image for larger version
  • 20 Peak HP gain depending on the dyno and modifications
  • 5-15 ft lb torque across the rev range
  • Rev limiter raised to 7600 rpm.
  • Improved throttle response
This program was not tuned specifically for an intake. Any correctly designed intake or exhaust modification should work well with this reflash.
211hp/187tq at the wheels on a stock setup...without mods :corndance:
at the bottom left of this page - share this page on FB/Twitter/Google+
there may be a giveaway based on your sharing
:hyper:
Could flashpro be right around the corner?!!?
It was like 2yrs behind the reflash on the 8th. Note- this was done without mods. The 8th was done with mods. I'm sure they need more aftermarket parts to hit the market for testing.
Sharing is Caring!!
What rpm does the VTEC kick in on the 9th? The one thing that I hate about my '08 TSX is that it kicks in at 6k and redlines at 7k....need more VTEC! :)
if I'm not mistaken...wasn't the 8th priced at $499 initially?
