420Coupe
- 262
- Vehicle Model
- LX
- Body Style
- Coupe
I thought you guys would definitely appreciate this.
Well since I have had so much down time with no car, I've some what been looking into other projects.. IE Hatch kswap etc. Decided to go bigger and better with improving the HOME!
Regardless been designing a SW aquarium+sump/filtration/reservoir to replace a portion of the wall in an L shape. The Aquarium its self will hold ~1800 gallons when filled, and the sump beneath a maximum capacity of ~ 650g as a reservoir and the entire filtration/heating system hidden beneath. On to the pictures!
Bottom
Top before plywood bottom
Top with plywood as bottom of tank
Sides
Isometric View
Reservoir highlighted
Regardless been designing a SW aquarium+sump/filtration/reservoir to replace a portion of the wall in an L shape. The Aquarium its self will hold ~1800 gallons when filled, and the sump beneath a maximum capacity of ~ 650g as a reservoir and the entire filtration/heating system hidden beneath. On to the pictures!Bottom
Sides
Isometric View
so i figured may as well go SW where i have to do less water changes. I'd recommend going SW its amazing the variety of fish compared to FW and BW. good thing is SW is cheaper for me because i will be spending 0$ on Live rock/Coral and just go out into the ocean and go pick up my own!!!
