brown_bear
MOAR LOWZ coming soon!!!!
oh yesMOAR LOWZ coming soon!!!!
^^^^^^^^^lol awesome pictures guys.
Quick question for you who have already gone lower, or used 8th gen springs, the only issue using the 8th gens springs is that the coil on the spring wont fit our 9th gens top rubber bushings, correct? with a simple purchase of those OEM parts (about $35) then we can use 8th gen springs without issues?
Also, are there any changes in strut/shock geometry from the 8th to the 9th? i ask because i have a guy here with a set of Konis and springs from an 8th gen Si Sedan, and i will pull the trigger if i wont have issues fitting them.
thanks in advance guys.
Where the lip @ ?![]()
Sent from Flyy Network.
http://9thcivic.com/forum/threads/honda-recalling-2012-civic-over-left-driveshaft.4704/My boy recently told me Honda is having over 50,000 recalls in civics. Something to do with driver side axel
From what I can tell, it doesn't affect Si owners.just checked my VIN....im good
is your car registered to 2 plates? some times you have the yellow ones other times the white and blues![]()
