TJ___90
come on why should something be trimmed . what if for any reason I have to remove it i'm i going to glue back that piece
I kinda have to agree with you guys. I'm not convinced that this is the way to go.Sorry to be the bad bearer on news but ur better off buying something else
I can't stop looking at your avatar pic, damn youKool u know the deal take pics
Ha ha, uhmmm... I will try my best. I'm having the homie Eddie Blanco help me with the installation, woot woot!!*cough* DIY DIY DIY *uncough*
Why would you ever have to glue it back??![]()
how similar is this to the 8thgen one? i didnt have to trim that one at all fit like a glove. just removed the blue cap with grease off the stock then put it on the extension and wamooooooo perfect
Just got mine today, does it supposed to come with two screws as described on the manual? I only received the short shifter and a small tube of grease.The installation is the same as the 8thgen adapter, with the exception that there will be a bit of plastic trimming needed (a small amount, about 1/4 inch of plastic).
What make was the 8thgen one you installed? Was it a CT Engineering?how similar is this to the 8thgen one? i didnt have to trim that one at all fit like a glove. just removed the blue cap with grease off the stock then put it on the extension and wamooooooo perfect
