bigjerm3284
- 0
Can I put a navigation on my si that does not have navigation?
I'm looking at aftermarket ones. Any in specific I should be looking at?
At the amp. Signal goes into the amp as Front left/ right and comes out front left/ right door and front left/right tweeterI have the Non-Navi (so called) Premium Sound in my 2012 Ex. Anyone know if there is a crossover built onto the tweeters? Or is the signal for the tweets separated at the amp?
Incorrect information. All outputs from the factory amp have filters because the crossovers are built into the amp. You will get horrible sound using an LOC on any channel after the factory amp because of Honda's lousy crossover frequencies inside the amp. You need to take the output directly from the head unit in a premium sound system, which is a pre-amp line level signal, but using differential balanced wiring, so a compatible amp is also necessary.If you use an loc, go off the sub because the rear speakers may have filters from the factory amp/hu
That is correct because of the differential balanced wiring and the fact that the outputs from the amp are all frequency filtered by the factory amp. No signal from the rear speakers was caused by the differential balanced wiring in the Honda and a non-compatible amp, and the lack of low notes and inconsistent sound was caused by the filtered signal from the amp output on the sub channel. If you do not get the proper sound quality or signal from the sub channel after the amp, then I would say that option does not work. Someone might think the sub is defective when they are giving it an improper signal, hoping to expect the correct sound.Note the "if", I said that because someone said they were getting nearly NO signal from the rear speakers, and I originally had my amp running high level input from the sub and it worked fine, but didn't play the VERY low notes and was often inconsistent... So it will work, just don't expect some great sq
Any chance you have the 2015 pin outs or are they the same?![]()
Hello! Is anyone home? This is a good thread... why let it die?Any chance you have the 2015 pin outs or are they the same?
thank you
yeah.... me too.....Anyone know where to get wiring harnesses for pre and post amp connectors? Figured it'd be easier to get those two, splice RCAs into pre amp harness and run those to my amps then run aftermarket amp output back to stock post amp connector so i dont have to run new wires to all my speakers.
Main reason I want the harnesses for those points is so i dont have to cut any wires and if I ever need to take my aftermarket system out it makes that a whole lots easier too.
PS would love a source that ships to Canada or sells in Canada
