Sucess! Pink is negative and blue is positive.
Pics tonight.
Pregnancy test? So confused without context...had to scroll up.
Pics tonight.
Hey man, that's what it's all about. Glad it was helpful!@jasonandre Thanks for the great DIY. Very clear and easy to follow.
I took a couple shortcuts. I didn't take off the pillar covers. I just fed the wire through. Also, I didn't take the two door sill plastic trim covers completely off. I just lifted them up on one side so I could get underneath.
That's extra work to do it that way. OEM doesn't even do it that way. Ha ha.I installed my door sills with a small twist: the four of them do not light at the same time when a door is opened but each lights independently when the correspondent door is opened and all the circuit can be turned on-off with a switch.
Ah haaaaa! Now I understand.In my case, not really. I used the same courtesy door lights circuit as a starting point, so it was very easy job.![]()
Pics tonight.
Prob should look at this diy - fuse 23Hi, I got a civic 2012 2 doors. Trying to install footlights, but can't figure the blue and pink wire. I tried the light blue with the 2 pinks (doors closed and dome light off) and still gets power.
Any idea what I'm doing wrong?
You will love them.After having these sit in my garage for about a year I'll finally be installing them
