- 57,144
- 24,326
only way I've ever seen people do it is by welding it,... grinding it all down, and repainting the trunk
Ah okay, that makes sense. I also forgot that it wasn't direct fitment for 8th gens anyway.there isn't a 9th gen type r. Even with the 8th gen people had to break tabs off - if that's what you're referring to?
should be the same. Can you measure the 2013 front emblem width/height?do the 2012 jdm badges fit the 2013 si sedan?
Yeah I can, what I'm curious about is the curve, if it will sit flush.should be the same. Can you measure the 2013 front emblem width/height?
Ill get back to you on the measurement
Just some advice for you:Kind of a late response, but they do fit the 2013 sedan. I just put mine on there and forgot to even check if they would. Kind of a leap of faith. :p
they fit no problem ordered from corsportKind of a late response, but they do fit the 2013 sedan. I just put mine on there and forgot to even check if they would. Kind of a leap of faith. :p
