baby_blue_6_4
Driver side lights up and has the auto feature, passenger side doesn't light up at all and I would like it to.
I have a 2014 si sedan.
Oh, okay. Yes, very doable. The shade of the two switches is a little different, but won't be noticeable when installed. It will only be seen when the two switches are side by side.Driver side lights up and has the auto feature, passenger side doesn't light up at all and I would like it to.
I added an LED. I'm not sure the OEM light would light up.Ok cool. Prob best to just leave it as is and not try to paint it to match then. Is the normal light color white though? I may pick up the switch if the part number is correct that I posted and get the led lights done later. I'd have them done in red though to match the si theme.
I would suggest you go to a dealership. Just open every back door of every model car they have and you should be able to find one that will work.If anyone can locate switches that would work to allow led light to shine through please send me a message.
