- 25,905
- 10,784
We did get a car in there once during a potential hail storm....i have photo evidence somewhere
Well, moving to another unit is just as much of a hassle. The reason I didn't move is that I didn't want to pack up my apartment again and the hassle of packing/moving/unpacking for HOURS to DAYS. Moving to another unit as a solution would be unacceptable, given that I could have just left like I really wanted to.If you are really concerned with the hassels of moving, then request another unit in the complex that is aviailale and dry.
83.56 Termination of rental agreement.--
(1) If the landlord materially fails to comply with s. 83.51(1) or material provisions of the rental agreement within 7 days after delivery of written notice by the tenant specifying the noncompliance and indicating the intention of the tenant to terminate the rental agreement by reason thereof, the tenant may terminate the rental agreement."
83.63 Casualty damage.--If the premises are damaged or destroyed other than by the wrongful or negligent acts of the tenant so that the enjoyment of the premises is substantially impaired, the tenant may terminate the rental agreement and immediately vacate the premises. The tenant may vacate the part of the premises rendered unusable by the casualty, in which case the tenant's liability for rent shall be reduced by the fair rental value of that part of the premises damaged or destroyed. If the rental agreement is terminated, the landlord shall comply with s. 83.49(3) [F.S. 1973].
mister webby even knows about things he's not supposed to know about! whatta boss!Have you ever had them try to fix/resolve other issues in the last year? Did they fix those things in a timely fashion? Working with contractors can be a mess in itself, so part of the issue can be just getting a person to look at the issue. I've had countless contractors flake on me, yet they assure you they'll be there at a set day/time. No call/no show. Anyway, that doesn't solve your leak. Your profile says you're in florida - florida state law:
THE LANDLORD'S RESPONSIBILITIES
* Florida Statutes, Section 83.51, require a landlord to comply with the local
Property Maintenance Code. This means:
1. The roof must not leak.
2. The walls must be weather-tight, and in good repair.
3. The stairs must be safe for normal use and maintained in good repair.
4. Windows and doors must be basically weather-tight, water-tight, rodent-proof,
and kept in sound working condition. Outside doors have to have proper
locks.
5. Window panes cannot have cracks and holes. Outside windows must have
screens.
6. Inside floors, walls, ceilings must be basically rodent-proof and kept in sound
condition and good repair, and should be safe.
7. The house or apartment must have hot water, which is connected to the
kitchen and bathroom sinks, tub or shower.
8. All houses or apartments must have a flush toilet in good working condition.
9. When cooking and heating equipment are provided by the landlord, they must
be safely installed and in good working order.
10. There must be adequate garbage disposal facilities or garbage storage
containers.
11. Every habitable room must have at least two separate floor or wall electric
outlets and, additionally, every kitchen, bedroom, bathroom and hallway
must have a ceiling or wall-type fixture, or an outlet controlled by a wall
switch near the entrance to the room.
12. All electrical systems must be in good repair and good working order.
IF THE LANDLORD DOES NOT COMPLY
* If your landlord has failed to comply with the previous listed code responsibilities,
and has ignored your request to undo their unlawful action, you can contact The
Code Enforcement Branch of city or county in which you reside and
request that they contact your landlord and explain that their action is illegal and
violates your local code.
* If your landlord fails to do what the law or lease requires, you may be able to
withhold the rent. You must give notice of your intention by certified mail at
least seven days before the rent is due to allow time for the landlord to remedy
the problem. If the problem is not corrected within seven days and you withhold
the rent the landlord may take you to court to collect it. You must them pay the
rent into the court registry pending the judges determination of the case.
Ah, that sucks.At least you have somewhere to go now? We have to be out of our townhouse by the 30th and don't know where we're going yet. :|
They won't let you do month-to-month if you're not ready to move out? Or do you own the townhouse and sold it?Yeah, that's no fun. It's a really cruddy situation they put you in.
Right now it's been next to impossible for us to find a place because as soon as we find it, it's gone! :\ Seller's market!
