DIY AP's Bi-Xenon Retrofit DIY Guide
Discussion in 'Lighting DIY' started by AlienPrime, Apr 20, 2013.
  1. FRDRICE
    FRDRICE Retrofit Much?
    296
    ATL
    Vehicle Model:
    '13 Civic Si
    Body Style:
    Use TRSTEN for 10% off. :)
    If your have any further questions don't hesitate to give me a call at TRS(Jamel)
  2. AlienPrime
    AlienPrime Well-Known Member
    3,058
    Sudbury, Ontario, Canada
    Vehicle Model:
    Civic Si HFP
    Body Style:
    2 door Coupe
    awesome!
  3. johnnyboy83
    johnnyboy83 Well-Known Member
    27
    Terrebonne, Quebec
    Thanks Jamel ;)
  4. A. G. Pym
    A. G. Pym Well-Known Member
    71
    Okay this is really looking too good to be true, unless I am missing something. Am I correct in understanding that the projector is only held on by a lock ring behind the headlight housing? No dremeling or screws or anything like that that I've seen with lots of other retrofits? And if that is the case, do your headlights bounce or is this a strong enough way of mounting the projectors that you don't have to worry about that? I had planned on buying an extra set of headlights and doing a retrofit as my winter project, but it's starting to look easier than I was expecting. Any clarification on this is much appreciated.
  5. squiggy
    squiggy Cartographer
    11,166
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    If your are only doing the low beams, the mini H1's will fit with no problem and be kept in place with the lock rings.
    A. G. Pym likes this.
  6. webby
    • 2019 Toys For Tots
    webby Administrator
    51,950
    just the lock rings are used. no dremel or cutting required
  7. A. G. Pym
    71
    @squiggy @webby thank you both for those quick responses. My retrofit just got a lot easier!
    webby likes this.
  8. AlienPrime
    3,058
    Vehicle Model:
    Civic Si HFP
    Body Style:
    2 door Coupe
    yay! Post when you're all done! :)
  9. xXCiviXx
    xXCiviXx Well-Known Member
    890
    Calgary, AB, Canada
    Vehicle Model:
    Si
    Body Style:
    Wish I saw this before I ordered mine lol
  10. xXCiviXx
    890
    Calgary, AB, Canada
    Vehicle Model:
    Si
    Body Style:
    Did you pull the projectors solenoid wires through the inside of the project and run the wires past the bulb like this? Or will this burn/ melt the wires?
  11. FRDRICE
    296
    ATL
    Vehicle Model:
    '13 Civic Si
    Body Style:
    Is that coming out of the bowl, like through the same hole the bulb goes in?
  12. xXCiviXx
    890
    Calgary, AB, Canada
    Vehicle Model:
    Si
    Body Style:
    Ya. In the instructions AP said to pull the wires through the projector and there wasn't any pics or further details. Wanted to double check before I went any further but decided not to run the solenoid wires so they're tucked away inside the headlight housing
  13. FRDRICE
    296
    ATL
    Vehicle Model:
    '13 Civic Si
    Body Style:
    You don't want to run them through the hole that the bulb goes in as they will melt in less than a min, you would run them on the outside along the bowl if you wanted to.
  14. Tom's Si
    Tom's Si Well-Known Member
    163
    Sarasota, FL
    Vehicle Model:
    Body Style:
    What/where is the best way to seal where the wires come out of the back of the housing?
  15. jord4n313
    jord4n313 Member
    3
    Guys I was wondering, if I wanted to do a quad bi-xenon setup with a projector in the high and low beam spot - would a projector mount just like this in the high beam spot? If not, how would you mount a projector in the high beam location?
  16. xXCiviXx
    890
    Calgary, AB, Canada
    Vehicle Model:
    Si
    Body Style:
    Should mount the same. I used a bi-xenon kit which allows 1 projector to function as high and low beam. Hope this helps
  17. webby
    webby Administrator
    51,950
    exactly the same as the low beam spot. Just threaded through the bulb hole.
  18. AlienPrime
    3,058
    Vehicle Model:
    Civic Si HFP
    Body Style:
    2 door Coupe
    you don't have to do any of it any certain way. As i have mentioned before i wired mine seperate so i have independant control of both factory high beam and my projector highbeam :)
Share This Page
