I don't think its that loud, but I occasionally, from day one, hear the fan blade touching something at low setting, particularly as it slows down to off.Anybody else think that the blower motor is a bit loud? Or is it just me?
It actually drives me nuts.
are the vents themselves making noise for you, or is this a different thing from this -
http://9thcivic.com/forum/threads/noise-coming-from-the-air-vent.4643/
Mine has been making a vibrating noise like there is something stuck in it. It happens when the fan is at about half. When it's on low or high, the sound and vibration stop. It's pretty loud when it happens however. I've only noticed it since I've started using the heater. Perhaps I'll post a video to show what I'm talking about.Anybody else think that the blower motor is a bit loud? Or is it just me?
For me it is not a problem per se, it is only that the fan is noisy, not defective just more intrusive than other cars. It sounds as it is running properly and evenly, just nosiy Lower speed, first notch is actually noisier than a few higher.
That explanation makes sense!I agree that the first notch seems noisier, but that is probably because there isn't as much air noise coming out of the vents to drown some of it out. I have no doubt that it is running properly. It is just too noisy in my opinion.
I had mine replaced, too, when I mentioned it to the dealer about 6 months ago. And the replacement's even LOUDER. I'm going to mention it again when I take it in for my next round of maintenance.
The first one sounded like the blades were rubbing on something. The replacement just sounds like a noisy motor--to me, it sounds like it's a pulse-modulated motor that you can hear pulsing on low speed. The only reason it goes away for me at higher speed is because the air "whoosh" is louder than the motor at that point.
And, yes, it absolutely drives me nuts.
