Diagnostic code P0420
John_chafin
14
Georgia
Civic
Si
I did a diagnostic on my 2012 civic si sedan today for a check emission light. It ran the code p0420 which with my research seems to be a bad O2 sensor? I'm just making sure this is correct and what my option of fixing it would be. Thanks guys!
Dennis Rockholt
9k Alll Day
1,952
869
Franklin, TN
370Z Fairlady aka "Nismo"
Did you recently install any sort of exhaust mods?
Dennis Rockholt
9k Alll Day
1,952
869
Franklin, TN
Well you probably damaged one of the 2 sensors during install I'd assume
Dennis Rockholt
9k Alll Day
1,952
869
Franklin, TN
I'd say the dealer...just because you want em to be good quality.
bardley
Active Member
That code is a catalyst efficiency below threshold code because the header you just installed has no cat. You can either get it fixed from a tune (which you should get any way) or try spark plug defoulers.
John_chafin
14
Georgia
Civic
Si
I did get it tuned but it came on after I got home from getting it tuned.
John_chafin
14
Georgia
Civic
Si
^that. Needs turned off in flashpro
We'll this morning I was driving and when I was down shifting my exhaust got extremely loud and vibrated underneath me, is this one of the symptoms of the o2 sensor not being cut off when he tuned it?
Phroze
157
Oklahoma City, Ok
just check it yourself if your settings, should be under sensors or something like that and you might need to have advanced parameters enabled.
22,442
It's doing to make more noise being new. Lots of catless downpipe owners say it changes after some use. Nothing to do with o2
John_chafin
14
Georgia
Civic
Si
This doesn't sound like it's setting in though. This sounds like something wrong I'm not sure.
Nix
Jötunn Moderator
10,765
8,162
Lew-vul, KY
It's A Fast Pig!
Check ya bolts and mounts. Other people have needed a stiffer exhaust mount to keep it from hitting in a couple places.
