John_chafin
Thanks guys for the help!
catless downpipes give this code. You have to remove the code with flashproWhat ended up being the problem? I got a fullrace catted dp and im getting the same code.
Catted Full-race will trigger code as well.catless downpipes give this code. You have to remove the code with flashpro
You need to turn off the O2 sensor in FlashPro.I have flashpro and did the reflash and its still one. Gunna flash the new calibration and see if it works.
If you're tuning with Vit, you should ask him
Pretty sure flash pro has an option to disable the secondary o2 sensor. Am aftermarket cat or a no cat situation will measure a bit differently on the 2nd o2 sensor and cause a check engine light.I've had my skunk2 header and exhaust on for about two months plus. Got a CEL in stop n go traffic for 20-30 min. Why would it start now? I'm using the reflash map because I'm early into calibrations wit Vit. Any help appreciated.
