So for the first time in two weeks it wasnt cold or potentially a tornado outside so i went to install my foglights.... and they didnt work
This was my failed setup:
I had the green wire plugged into the ignition fuse in the engine bay, one ground on the frame, one ground on the (-) terminal of the battery and the white wire tapped into the #12 fuse that said foglights in the engine bay. The switch was in the proper spot, and worked/lit up but never turned off, and to my dismay, my lights werent on.
Pauly99to17 I used the diagram you sent me and there were extra wires I didnt know what to do with, thats where things got a little sketchy. I couldnt really make everything fit so i had to leave the important looking wires in the engine bay. Would buying extra wires to splice and run into the cabin fuse box help get my wires into the right fuse? Since you have the Spyder kit, you'd probably know what I mean with respect to the colored wires.
And again, I'm sorry that I keep having to ask over and over. Thanks a ton for helping me out this much guys!
