Grinding sound '14 Si
Discussion in 'General Chat' started by XxDGeezyxX, Nov 20, 2014.
  1. XxDGeezyxX
    XxDGeezyxX Well-Known Member
    21
    During a cold start right after the motor turns over and fires there is a split second sound of something grinding. Car drives fine, no clutch problems, etc. Anyone have any ideas or having the same problem?
    krispykareem29 likes this.
  2. webby
    • 2019 Toys For Tots
    webby Administrator
    51,394
    have you checked your oil level to make sure you're within the safe area recently?
  3. Redrocket1
    Redrocket1 Well-Known Member
    149
    Kalamazoo, MI
    Vehicle Model:
    Body Style:
    Isn't this the 'cold start scraping' noise? There's a thread on that somewhere.
  4. XxDGeezyxX
    21
    Oil level is fine, I check it every other day. And yes it's a scraping/grinding noise from a cold start from sitting overnight.
  5. webby
    webby Administrator
    51,394
  6. Redrocket1
    149
    Kalamazoo, MI
    Vehicle Model:
    Body Style:
  7. krispykareem29
    krispykareem29 Active Member
    2
    Same problems 2013 si sedan
  8. Daniel Bivona
    Daniel Bivona Well-Known Member
    178
    Pompton Plains, NJ
    Vehicle Model:
    Si
    Body Style:
    FB6
    This isn't a problem, it happens more or less during cold temperatures. I have the same thing on my 2013 Si. Happens mostly in freezing temps.
  9. randyO
    randyO Well-Known Member
    148
    I have had it happen to me 4 times now. The only time it does it is below freezing. I have 4000 miles on my car so it had me worried for sure.
  10. krispykareem29
    2
    It's the vtc actuator same thing happened to mine
  11. thatblackfb6
    thatblackfb6 Active Member
    42
    yeah go to Honda and get them to check out the vtc actuator it should definitely be under warranty still
  12. JonnyRotten
    JonnyRotten Well-Known Member
    1,673
    Mississauga, Ontario, Canada
    Vehicle Model:
    Body Style:
    coupe
    Check the thread @webby posted. I would call it a vibration noise, not a grinding noise. The sound is the vtec actuator vibrating because of the lack of oil pressure for a split second.
    My 2014 Si does it on cold starts.
  13. bowler13joe
    bowler13joe Well-Known Member
    91
    Upstate New York
    Vehicle Model:
    Body Style:
    Happens almost every time with my 13 sedan. I actually heard it happen this morning on my lady's 08 CR-V, for this first time, as well.
    Daniel Bivona likes this.
Share This Page
