Neil
- 6
I see what your saying, but there are many variables that factor in. It would be better for fullrace to explain this.
Ok so hypothetically speaking for us average people just bolting up a turbo on low psi and tuning it would be more cost effective vs a head swap with the 20 some odd parts hytech said needed to be swapped.
I'd have to see what kind of numbers they're getting from the k20 head/exhaust combo...and how expensive the parts are. No clue what the 20 or whatever parts cost ...
without a doubt you'd have higher hp #'s going turbo... I won't argue that. I've seen a few sites that sell machined/remanufactured k20 heads for like 500. Again... it's still unknown how expensive the other parts are for the swap. 270-300hp all motor is nothing to sneeze at.
I believe the last time someone called f-r about their turbo it was like $5,5XX range. Then add flashpro, exhaust, injectors, etc...
Why choose just one?
No one said you had to do it all at once
Well, because it's physically impossible to be both turbocharged and naturally aspirated.Why choose just one?
= bent piston rods. Lol.typically if you go all motor, you run 12.5:1 or higher compression.
High compression + boost = no bueno
Oh my I had no idea, thank you for your enlightenment.Well, because it's physically impossible to be both turbocharged and naturally aspirated.
You are so very welcome.Oh my I had no idea, thank you for your enlightenment.
Nope didn't read a damn thingHave you read this thread at all? The integrated header cast into the head of the K24Z7 is ideal for turbocharging. Doing a head swap to a K20 head to go turbo would be completely counter productive and one of the most fiscally irresponsible things you could possibly do.
