- 57,216
- 24,355
it looks good.... like it could come stock that way
The inner dia is 78mm but the outer dia is close to 3.25". The MAP sensor actually goes on the intake manifold. I think you're talking about the AIT sensor.
PRL Motorsports said:Looks great steve!
for those of you doing the ZDX throttle body, one of steve's questions was about the extra sensor on top of the throttle body. that just gets left unplugged. The ZDX has the map sensor on the throttle body, where as the 9th gen and the RBC is mounted to the intake manifold. the ZDX comes with the map sensor installed, so it needs left in there to plug the hole or else it would have a vacuum leak. so yeah, just leave it in there unplugged. you'll install your stock map sensor into the rbc manifold and plug the blue 3 pin connector into that.
