Jeffuhnator
Thanks for the input everybody! Whatever it was, it's gone now. I took out the shock/struts and flipped the rubber grommet thingy to the proper position. The right side bolt on camber arm on the rear passenger side wasn't tightened properly all the way onto the frame/chassis. The rear sway bar on the rear driver's side wasn't tightened correctly either. it seems that there was a combo of the nut and allen key just like the top of the strut but on the sway bar. i fixed that too, made sure everything was tightened. I also sprayed all the bushings and spring isolators with food grade silicone. Now I'm golden. It could have been anything or everything. Just a quick rundown was all it took.
