Jonathong
Any have this setup? Car to chime in any gains or even louder at wot? Any input is greatly appreciated.
IM and TB thermal gaskets are much better than the P2R spacer.
Also any cons to removing the resonator? Do I lose anything?
No, the spacer does nothing for what it is worth.
The thermal gaskets are all you'll need. Adding an extra 1" thick aluminum for performance makes no sense.
True but the heat isn't going to sink all the way through the plastic to the aluminum...and if it does, I don't think a gasket will do much to stop itI believe the IM is half composite and the runners are made of aluminum.
