Cool updates man. Been waiting to see what you were up to with this.
The Corvette Forum is an excellent option. Another is to establish a relationship with other restorers in the local /state Corvette club for advice. I would highly recommend joining the National Corvette Restorers Society (http://www.ncrs.org/) as they offer restoration seminars and numerous restoration reference books which are invaluable to both the novice and experienced restorer. This includes information which can help discern if a part was commonly found on 1962 Corvette factory cars or if it is aftermarket, etc. Part number look up references can be very helpful. They also have knowledge of local machine shop and restoration resources, as well as national resources.
A bent frame indicates frame and body damage. Is the frame straight at this time or does it need further work? Attempt to understand the extent of thecollision damage to the body. There are many clues. Were numerous body mount shims found on the car during dismantling? Are body parts in proper alignment, do the doors sag, etc. I remember one frame in which extra washers were used between the engine block and the engine mount to fill in the space gap from an improperly straightened frame. Be observant as the clues are there but may not be obvious.
Sorry I could not be of more help. Local support is the best option I can recommend for this C1.
We may be able to help him with originality if he provides photos of the GM block casting number on the driver side engine bell housing flange and a photograph or pencil tracing of the numbers on a flat pad located on the front passenger side of the block just below the engine head. These are clues to originality that can be looked up in reference books.
Here is the thread from that ^ guy.> http://www.digitalcorvettes.com/forums/showthread.php?t=112313
He actually posted a more novel way to do it...
AWESOME!!!!I take it you didn't have any issues with the forklift lifting it off?
yeah the cylinder walls seem fine. those marks look like they were left from honing the bore. there's nothing deep that catches.Are the cylinder wall marks ok? Nothing you can catch a fingernail in?
