OEM Switches?
Gugs
18
San Francisco Bay Area
Si
Hi guys. I have a question about switches or other OEM items that may reside where these blanks are on my '13 Si.
What do you guys have occupying these spaces on the non -Si? Fog light switch? Rear fog light switches in non-US models? Oil slick or smoke screen?ImageUploadedByTapatalk1393886665.749971.jpg
Very cool. Thank you! Do you think you could snap a close up of the switches? The ambient lighting is pretty sweet!
i have all three filled as well
Bixenon, footwell lighting, center console lighting
5 wires each switch, fills up fast! Here is a pic in testing phase hahahah!
only rates to 15A tho. Never exceed that!
Here it is all completed :)
where did u get the fog light switch both fo the aftermarket foglight i bought has switches that are bigger then the slot
Welcome to the forum.
The button came with the Spyder Fog light kit that I bought.
http://9thcivic.com/forum/threads/pics-just-installed-spyder-oem-fog-lights-on-lx-coupe.6353/
I had to trim the button a touch for it to be flush. Plus, it was getting stuck a little bit because it was a little too long and would getter sandwiched/pinched when I pushed the button in to turn them on. You can see the cut I did here.....
http://9thcivic.com/forum/threads/paulys-youre-my-boy-blue.6598/page-14#post-218046
In the '13 Coupe EX-L, the only switch occupied is the traction control off button. The other two are blank. The EX-L comes with fog lights standard, so the fog switch is a rotating dial on the headlight/turn signal control stalk. The EX-L also has auto headlights so the control stalk is different than lower models.
