Oil change 10,000 miles
Where I'm at 4 quarts cost about 130 dollars for the cheapest stuff
What do shops charge for an oil change? What's a normal hourly wage there for comparison...
I am in Germany at thw moment. So everything depends on the exchange rate.
My si has run a little over 2k miles in the past 1 year. The oil indicator shows lots of life left. Is it really ok to go on? I'm used to changing oil in my much other car (turbodiesel) every 6 months regardless of usage.
change the oil yourself and use only the best, I would not trust a oil change shop. They use the cheapest junk oil and filters are garbage too. I would not use the oil change indicator-its mostly for idiots and the oil is bad or not as good anymore when it hits 40%.:barf:
I'm not used to wrenching, so will have to get it done somewhere else. Probably will take it to a dealer or a nearby garage that has very good reviews
Where are you located?
Sent from my SM-G955U using Tapatalk
Supposedly the oil starts to oxidize after being in the engine after a year. The oil is being exposed to changing temps and humidity and since its not a 'closed' system moisture can enter the ending and mix with the oil. This is the reason why oil companies say xxx miles or up to 1 year
I'm in Norwalk, Connecticut. My other car is in India - Where we love our diesel hatches ( they outsold the petrols until very recently when we started to implement our version of Euro VI)
more on it here What else do you drive?
