I've seen a few of you guys say you're still running stock with no issue, so I really don't wanna pay that additional cost because they decided they only wanted to sell the 24mm with the adjustables I don't even want.
No the bar came with the adjustables, I just didn't feel the need to install them. MY car is not lowered so the stock ones kept the bat level at ride height like it is supposed to be. If i ever get coil overs I will go back and install the adjustable links to compensate.You're running the stock end links? Does that mean that you were able to find the bar by itself? I'm only finding the kit with the adjustables that everyone is saying clunk.
do the pics of the bar & parts match up to the parts you have on your car?That's how the one I got off the car looks compared to the stock one I ordered, not knowing that I had an aftermarket sway bar. Also I tried to measure the bar and it came up as a 23.5 mm. So I assumed that it was the 24 mm that is discussed in this topic. When I measured the bushings that came off the car, the inside diameter was like 23mm. So should I order another set, like a 1 mm less than what I have now? Or you think the play I still have is to blame on the end links?
