- 57,188
- 24,270
My bad...you are correct. I could have sworn I read an article saying Exxon had bought them out.
Bump on this questionI usually run 91 but have noticed the Mobil sells 93. Is the 93 worth the extra 15 cents a mile?
All the top tier stations and gulf all have 93 and not 91 here it's strange but convenient. Found a shell right by my work that has 93 for the same price as cheaper stations. I use an app called gas buddy it's incredible.I would say negligible difference. The car mentions 91 as the required octane level in the manual. I'm surprised you can get 91 and 93 in your area. Usually it's one or the other from what I've seen.
Recommended means not required therefor they can not deny you warranty workI am a Service Advisor and I can promise you that manufacturers take fuel samples from the tanks of cars that come in under warranty for engine problems.
Maybe not noticed by you, but probably still there and possibly able to be noticed by someone else. Perhaps you just want to believe so badly that there is no difference that you are just not noticing... Try 89 at a few different gas stations, then dyno the car. I guarantee you will make less power than someone with identical car running 91+.There is no change what so ever in mpg at all and no noticeable power loss.
It is well known that retarding the timing decreases power. The engine retards the timing to compensate for the lower octane. This is fact.
OR maybe even you are really lucky and the gas station's 89 octane is actually higher than that and enough to cause no problem. The octane rating on the pump really is just an estimate and different factors can contribute to it being wrong by a couple of points, and not always in the negative direction.
Plus you are cruising. Pinging would be most increased during acceleration. How can you comment much on performance when you're cruising around 99% of the time (I am guessing, since you mention 3AM and being on cruise)? That's not performance-demanding driving at all
Nah, I didn't take it as you saying better performance with 89. I understood.performance change sure maybe there is some that i cant tell and maybe you could. i hope you didnt take this as its better performance. i was filling my car every two days to three days putting in gas that was 23 cents more per gallon to just burn it cruising on the high way. i tryed a couple tanks of 89 and it seemed to run fine for what i was using it for. i still had my fun at stop lights and on ramps and i noticed no difference. i use shell so i was going from 93 to 89. this was just my point of view from a commuter.
Is 89 regular where you are at? Here and many other places it is 87. So, to me, you're running mid-grade. Definitely not going to be as noticeable as running regular 87 which is the standard in many places (although I don't know exactly where else 87 is regular, i'm in FL… I do know that it's regular in other states too though, can't remember which ones). That's because the engine doesn't need to compensate as much by retarding ignition timing with 89 since it's only 2 octane points below the recommended 91… it's not going to ping as much as 87 would.
Maybe try some other gas stations with 89 octane for more sample size?
So, maybe 89 is "okay", but I wouldn't run it in my K24 personally. And I definitely would steer anyone else away from using 87.
You do know you're only saving like 50 cents a day or less then right?As soon as I'm not driving 160 miles a day premium will be back in it
around a dollar a day but that makes a significant difference in my situation right nowYou do know you're only saving like 50 cents a day or less then right?
Where I'm at its like 10 cents more for the next grade above 89 (91 or 93, both at least the Si's recommended octane).around a dollar a day but that makes a significant difference in my situation right now
