Shifting into 6th gear
Discussion in 'Civic Si Models' started by eric.schwartz., Apr 2, 2015.
  1. eric.schwartz.
    eric.schwartz. Well-Known Member
    295
    Marlboro, New Jersey
    Hi everyone, as some of you probably already know ever 2014 civic Si I wish I love! But I have a general observation for everyone here, has anyone noticed driving the new ones that shifting from 5th gear into 6th gear final drive, is in the rest was smooth? Maybe it's just me, but I'll gently shift into neutral then quickly shift into 6 th gear. when I'm driving on the highway and that seems much smoother.
  2. webby
    • 2020 Toys For Tots
    webby Administrator
    52,102
    please read that again and explain. I'm not following what you're trying to say
  3. eric.schwartz.
    295
    Sorry again, shifting from 5th gear to six gear it's kind of tough. I usually shift directly from 5th into a neutral neutral and then into 6 Quickly. Does anyone else experienced this at all?
  4. squiggy
    squiggy Cartographer
    11,183
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    6th is sticky with this car.
    Not sure what you mean by shifting into neutral and then sixth unless you essentially mean double-clutching.
    Get a heavier knob and it will help alleviate what your a feeling somewhat.
  5. eric.schwartz.
    295
    I am trying to explain it correctly its just a little weird shifting but its not a big deal though. I figured I'd mention it once though.. I love the stock gear shifter as everything else here. Lol
  6. bram24681012
    bram24681012 Well-Known Member
    22
    I know what your saying. I used to shift into neutral before 6th when I first got my car. Eventually you'll get the hang of it and smoothly shift from 5th to 6th. Just keep practicing
  7. eric.schwartz.
    295
    Thanks so much for your help.
  8. Monk
    Monk Well-Known Member
    4,218
    SW Virginia
    Vehicle Model:
    2012 Civic EX
    Body Style:
    Coupe FG3:ASM
    I'd say a lot of times with the newer cars that have a top-gear that's in the over-drive ratio of things, that it can be due to the equivalent of short shifting, when going for 6th, where as taking the rpm's up some more would probably negate the issue.
  9. JonnyRotten
    JonnyRotten Well-Known Member
    1,673
    Mississauga, Ontario, Canada
    Vehicle Model:
    Body Style:
    coupe
    This is so confusing to read...:think:
    @eric.schwartz. are you using a translator to come up with your posts?:confuzzled:
  10. webby
    webby Administrator
    52,102
  11. JonnyRotten
    1,673
    Vehicle Model:
    Body Style:
    coupe
    @webby I was trying to figure out why his posts were not written properly. I was thinking that he might be using some type of translator software to translate to english from another language. Sometimes the words don't exactly translate properly from other languages to english because the software translates literally word for word.
  12. webby
    webby Administrator
    52,102
    I didn't understand what was being said, which is why I asked for clarification. He replied under my post & it made more sense.
  13. Bulkybear
    Bulkybear Well-Known Member
    1,665
    6th can be hard headed sometimes. But it's usually because you are not pulling straight down on the shift. Your pulling down and slightly towards you and just don't notice it due to our arms natural range of motion at that angle. Also, my ocd is forcing me to tell ya that you hit neutral every time you shift a manual transmission. There is no way to go from one gear to another without going through neutral.
    JonnyRotten, Monk and squiggy like this.
  14. OldmanTypeR
    OldmanTypeR Active Member
    13
    my 6th has a slight hitch to it I have to actually push slightly toward the passenger side to have a smooth downward pull. And yes I've driven many 6 speed cars. I figure it may break in or I'll get it fixed by Honda. It only has 200 miles on it. All other gears are butter as expected.
  15. eric.schwartz.
    295
    Yeah usually whenever I'm shifting I shift into neutral, them 6th gear anyways. It is a bit tough to shift directly into 6th gear, so I don't. As for my postings well sorry, I usually use voice typing and proof read my typing before I submit it but everyone messes up from time to time. That's all I've got to say.
  16. 13blacksedan
    13blacksedan Well-Known Member
    266
    6th is high, but I have had no problems.. I've ran 5th high and been fine...
  17. 13blacksedan
    266
    Only a couple times but I had no problems, I've ran 130+ and it was so smooth I felt going into 6th i was surprised it was so smooth
  18. 13blacksedan
    266
    The parkway in pittsburgh is a wonderful place
  19. JonnyRotten
    1,673
    Vehicle Model:
    Body Style:
    coupe
    6th is like overdrive so that's normal.
    I think the other thing to keep in mind is that the shifter naturally wants to spring back to the centre so you have to push it away when coming down from 5th to 6th.
  20. webby
    webby Administrator
    52,102
    Double the speed limit in the state is automatic jail time and license suspension.
Share This Page
