- 57,147
- 24,328
newer civics 14/15 have a way to reset through the imid. The 12/13's don't.
Yes I know this but the sensor is part of the valve stem.The sensor is in the rim not on the tire
Mine is a 13 and my valve stems are metal not rubber. And also with the 14-15 you can auto reset the TPMS inside the car. But for the 13s are TPMS is connected to the Valve stems just like the 12s but the 12s and 13s use a deferent TPMS sensor I believe it's why you can't put 2012 wheels on a 13 vis versa. My buddy did this and he had to replace the whole TPMS sensor on all four.If I'm not mistake (and this only apply's to 14-15's) the TPMS reads off wheel speed sensors. I could be totally wrong but i thought i read that somewhere (possibly owners manual) and having flexible rubber valve stems is another hint to me. Although ford used rubber valves stems for TPMS but they didn't flex much.
The sensors all have a unique id number on them. Each one is programmed to the car. If you swap to someone else's wheels, it won't see the correct info & throw an error. The wheels could have been left as is and just reprogrammed at the dealer.Mine is a 13 and my valve stems are metal not rubber. And also with the 14-15 you can auto reset the TPMS inside the car. But for the 13s are TPMS is connected to the Valve stems just like the 12s but the 12s and 13s use a deferent TPMS sensor I believe it's why you can't put 2012 wheels on a 13 vis versa. My buddy did this and he had to replace the whole TPMS sensor on all four.
and you can swap winter/summer wheels without having to have things reprogrammed constantly. That is the biggest bonusI personally like the wheel speed sensor style since there's less risk of damaging the sensor when mounting wheels and TPMS batteries will die over time and must be replaced with a new sensor.
