Undecided on springs... any help?
Yeah there are 4 clips around I think. The clip that's in the middle is now missing. :P
Prokit. The sport lines are in the same 2" drop range that the skunk springs are in. The prokit are a 1" approximately while the H&R are closer to 1.5" and I believe the skunk2/sportlines are 2"-ish.
Pretty sure the pro kit is a 1.6" drop in the front and a 1.5" in the back for a 14'si sedan. Just going by memory though not positive
Prokits are just over 1" - listed 1.2" so I bet 1.5" or 1.6" is probably pretty close to accurate.
http://www.wesellcarparts.com/store/scripts/prodView.asp?idproduct=9616
Sportlines:
Stated 1.8 - 1.5 so probably close to 2" all around:
http://www.wesellcarparts.com/store/scripts/prodView.asp?idproduct=9850
I know these aren't specific to the 2014 yet but I'm sure drops will be in the same range, prokit less than the sport lines.
H&R list right in between both of those.
http://www.wesellcarparts.com/store/scripts/prodView.asp?idproduct=9728
AH nice! Thanks man. I did not know that the 14' had a different drop with the same spring from the 2012/2013. I hadn't seen the 14 fitment listed yet either though when I looked. Great info.
No worries bro,I'm in the same boat trying what springs to drop mine in this coming spring, so I've been researching alot lol. I was considering the sportlines or the h&r's but if the pro kit is that low maybe I'll do that. It's a decent drop
my eibach is going to be delivered today and ordered some koni yellows that im going to cancel. i have only 9000 kms on my car and im going to ruin my front struts if im going to install the koni. I taught that its just plug and play for the front struts. im going to wait for struts to blow or buy some old struts for the front konis
