JDM Valve cover
nemesis249mp
19
Does anyone know if we can purchase these anywhere?
I have checked the vendors and don't see anything. Any help would be appreciated.
Michal006
4,674
PA
Tacoma TRD Sport 4x4 6MT
Access Cab
Jdm or carbon fiber? I don't think there is jdm valve cover
Nomar06
Super Moderator
Super Mod
7,826
4,938
Charlotte, NC
Fiesta ST (FiST)
hatch
Jdm or carbon fiber? I don't there is jdm valve cover
I believe he means this....
Not 100% sure, but I think the K24 and the K20 motors use the same cover. If they do, then you should be able to buy it from a bunch of places online.
Michal006
4,674
PA
Access Cab
Why not remove your original valve cover and paint it?
Dar-Dar
Mordorator
19,329
9,900
North NJ
not 100% sure on this but I remember reading somewhere that if you use the k20a (type r) valve cover on the k24z7 it will leak oil by the cam sprockets because the k24 valve cover is slightly wider. Again not 100% sure.
Yes, leaking will occur due to the differences in dimensions.
The K20 valve cover is not interchangeable with the 2012-2015 K24 VC.
victor nieves
Active Member
23
9
New Bern, NC
civic si-FB6
sedan
k20 valve will not work with out modification. the k24 side is wider on the cam gear side and k20 will have to shaved down for proper fitment and clearing of internals.
