2012+ Honda Civic Suspension Options With Product Info & Links
Discussion in 'Suspension And Brakes' started by webby, Feb 13, 2013.
  1. xXFlash21Xx
    xXFlash21Xx Well-Known Member
    359
    Myrtle Beach, SC
    Vehicle Model:
    Civic
    Body Style:
    Does anyone know if 8th gen coilovers fit 9th gen?
  2. squiggy
    • 2019 Toys For Tots
    squiggy Cartographer
    10,931
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
  3. xXFlash21Xx
    359
    Myrtle Beach, SC
    Vehicle Model:
    Civic
    Body Style:
    squiggy thanks! Has anyone on the site done this yet?
  4. squiggy
    10,931
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    Not that I am aware of, but there may be.
  5. webby
    webby Administrator
    50,368
  6. Chief Alabaster
    Chief Alabaster Well-Known Member
    81
    Orange County, California
    Vehicle Model:
    EX-L
    Body Style:
    What are my options for lowering my EX sedan? I was looking at the Skunk2 lowering springs but do I need the Skunk2 rear Caber kit and front camber bolts to go with the lowering springs?
    Much thanks for any contributed help, im lost.
  7. squiggy
    10,931
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    Any springs with a 2" or greater drop will require camber arms and bolts. You can use any brand camber kit.
    webby likes this.
  8. phil136
    phil136 Well-Known Member
    363
    Los Angeles CA
    Vehicle Model:
    Civic LX
    Body Style:
    Some sites list the Pro-kit springs for the 12-13 civic sedan (non-Si) 1.0" front , 0.7" rear. Others have it as 1.2/1.0 as OP listed. Does eibach make 2 variants?
  9. webby
    webby Administrator
    50,368
    for the non-si... directly from the eibach website:
    the prokit
    coupe
    Front: 1.2 in
    Rear: 1.0 in
    sedan
    Front: 1.0 in
    Rear: 0.7 in
  10. phil136
    363
    Los Angeles CA
    Vehicle Model:
    Civic LX
    Body Style:
    Thanks webby. So the look of the car will be largely the same as your image in the first post? I mean its only 0.2-0.3 difference for coupe.
    I assume its to compensate for sedan weight difference?
  11. phil136
    363
    Los Angeles CA
    Vehicle Model:
    Civic LX
    Body Style:
    Ride comfort for TEIN, H&R, and Eiback pro kit. Would they be about the same? Spring Rates?
  12. webby
    webby Administrator
    50,368
    The look of the car would basically be identical. I don't know the spring rates on the various brands. You'd probably have to ask each manufacturer for that info. I just pulled data from their sites.
  13. phil136
    363
    Los Angeles CA
    Vehicle Model:
    Civic LX
    Body Style:
    Anyone know the OEM spring rates for non-Si? I'm guessing around 170-200 lbs/in.
  14. webby
    webby Administrator
    50,368
    I haven't seen non-si spring rates posted. The 8th gen non-si were:
    Front 170~175 lbs. / inch
    Rear 200 ~ 205 lbs. / inch
    phil136 likes this.
  15. phil136
    363
    Los Angeles CA
    Vehicle Model:
    Civic LX
    Body Style:
    Thanks Webby
  16. Nix
    Nix Jötunn Moderator
    10,765
    Lew-vul, KY
    Body Style:
    It's A Fast Pig!
    Prokit are almost identical spring rates to stock.
    H&R are about 10% stiffer than stock.
    Tein I dont know.
    phil136 likes this.
  17. ryguy
    ryguy Active Member
    23
    Midland Ontario
    Vehicle Model:
    Civic si HFP
    Body Style:
    I'm thinking of going for ksport coilovers, I'm looking for not to stiff of a ride but stiffer than factory setup, has anyone used this set up?? And if so how is the ride?? And also has there been any problems with them?
  18. webby
    webby Administrator
    50,368
    tein for the non-si are rated 235
    phil136 likes this.
  19. phil136
    363
    Los Angeles CA
    Vehicle Model:
    Civic LX
    Body Style:
    Seeing how much springs plus a set of of koni shocks will cost me (plus the extra labor for Koni), Im considering going for the Megan/D2 coilovers. Yay or Nay?
    On a side note; can anyone give me an estimate of OEM struts' life with H&R sport springs.
  20. webby
    webby Administrator
    50,368
    07TLX Nix Dar-Dar may know from first hand experience on the 8th gens, or from the 8th forum? I'm sure it's going to depend on how low the aftermarket springs are, and how hard you are on the car.
Share This Page
