Clutch Noise
Discussion in 'Mechanical Problems & Technical Chat' started by TeeEyeVany, Dec 13, 2012.
  1. LaloGstreet
    LaloGstreet Well-Known Member
    4
    Houston, Tx
    Vehicle Model:
    Body Style:
    Thank you and pardon my ignorance, I've heard talk about tsb but I'm not entirely sure what it is or where I can find it and would it help me present my case at the dealership. I suppose there would need to be a recall in order for me to go to a Honda dealership which doesn't look like its going to happen.
  2. webby
    • 2019 Toys For Tots
    webby Administrator
    50,708
    the only service bulletin I see on the clutch -
    SUMMARY:
    HONDA: WHEN ACCELERATING FROM A STOP, IN SOME VEHICLES, NOISE IS HEARD FROM CLUTCH WHILE ENGAGED IN 1ST GEAR, AND SOUNDS LIKE A SQUEAKING, OR GROANING, OR GRINDING, RUBBING OR METALLIC. MODEL 2012 CIVIC. *PE
    Service Bulletin No.: SB-10-11
    NHTSA ID Number: 10053784
    PainlessCandy and JonnyRotten like this.
  3. Nomar06
    Nomar06 Super Moderator
    7,418
    Charlotte, NC
    Vehicle Model:
    Fiesta ST (FiST)
    Body Style:
    hatch
    Talked to my friend at the dealership and I have to get with him on Monday to set a time to bring the car in.
  4. webby
    webby Administrator
    50,708
    he planning to tear into it to see what it looks like?
  5. Nomar06
    7,418
    Charlotte, NC
    Vehicle Model:
    Fiesta ST (FiST)
    Body Style:
    hatch
    Prob going to drive it around to replicate the sound and go from there. He checked for TSB under a 2015 Si but nothing came up. Might have to show him this thread.
  6. MissE
    MissE Well-Known Member
    401
    New Brunswick, Canada
    Vehicle Model:
    Civic Si w/Navi
    Body Style:
    I think the TSB is only for the 2012 model, but even at that they still don't want to repair my 2012 either. So it's basically a crap shoot.
  7. LaloGstreet
    4
    Houston, Tx
    Vehicle Model:
    Body Style:
    Just curious, would upgrading the clutch get rid of this issue?
  8. Nomar06
    7,418
    Charlotte, NC
    Vehicle Model:
    Fiesta ST (FiST)
    Body Style:
    hatch
    Hello stranger! lol
    He mentioned that TSBs are year and vin specific so he basically knew he wasn't going to find anything. Just gave him the TSB info for his knowledge and basically let him know that it is an issue across different model years. He also mentioned that the TSB wouldn't matter if the noise was bad enough to warrant a teardown of the clutch to investigate.
    In your case.....try a different dealership and mention that other 2012s are having issues and that customers are having parts replaced free of charge. Also call Honda of Canada? and open up a case.
  9. PainlessCandy
    PainlessCandy Well-Known Member
    350
    Cleveland
    Vehicle Model:
    Body Style:
    @MissE Check out my post earlier in this thread; this is what is causing the noise:
    I had to fight with my dealership to get them to do the work, but I was certain that I had the same problem as others before me and that the wear on the clutch would not show any reason for this to be caused by me, but instead to be covered under warranty. The best way to reproduce the noise for them is on a hill from a stop. Going up the hill, give a little rev and release the clutch; with a very small amount of practice you'll be able to get it to happen most of the time, then you can show the tech at your dealership so there is no question about the noise being present. They will tell you that if they find excessive wear when they do the tear down that you will be responsible for paying for the work - it does not sound like you have abused the car or the clutch in any way so I would not worry. I had more than 33k miles on mine driving hard and my friction plate looked like new.
    Honda knows about this problem, and they will replace 1 (ONE) clutch assembly per car under "good will" since it is technically a wear item but the problem is covered under warranty as the part of the clutch in question - the dampening springs - should not be wearing at all. It was a great help for me to open a case with Honda Corp of America (I'm assuming you would have to call Honda Canada). Once Honda Corp contacted my dealership they were much more agreeable to fixing this issue under warranty, though they still tried to scare me with threats of me having to cover the cost if they found signs of abuse.
    MissE likes this.
  10. PainlessCandy
    350
    Cleveland
    Vehicle Model:
    Body Style:
    Yes, replacing the clutch disk which houses the springs that make this noise will solve this problem (see my post link above). It should be noted that after having their stock clutch replaced with a new stock clutch, the problem has reappeared for several owners after another ~30k miles. I believe this has to do with our flimsy rear engine mounts and that replacing the mount will reduce the chances of this problem reoccurring, or happening in the first place for new buyers. This is also something to consider if you are planning on boosting the car later as you will need to replace the clutch with something better than stock depending on how much power you add anyways.
    LaloGstreet likes this.
  11. squiggy
    squiggy Cartographer
    10,970
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    I have had a rear Hasport motor mount since about 10k miles (now at 30k) and do not have problems or noises from my clutch.
    PainlessCandy and LaloGstreet like this.
  12. LaloGstreet
    4
    Houston, Tx
    Vehicle Model:
    Body Style:
    Thanks for the info, I guess I'll go to the dealership that sold me the car and hope that is covered by their 2 year warranty on it. Worst case scenario and it's not covered, would anyone know about how long the car can go with this noise until the clutch starts failing? Its not something I want to do but money is kind of tight right now.
    dbosch likes this.
  13. FooBird
    • Supporting Member
    FooBird If the Foo...well, you know. Just wear it.
    5,892
    Kirkland, WA
    Vehicle Model:
    Si
    Body Style:
    Interesting on the motor mount front. I have the garage and if I have the motivation and time. Wouldn't want this coming back a second time.
  14. FooBird
    • Supporting Member
    5,892
    Kirkland, WA
    Vehicle Model:
    Si
    Body Style:
    I know of one guy who went for about 100k miles before he decided to go get it taken care of. It can go for a while, it's just annoying. But it's all going to depend on what conditions you drive in and how, in general, your clutching abilities are.
  15. Mikeorock
    Mikeorock Well-Known Member
    424
    queens, ny
    Vehicle Model:
    civic si
    Body Style:
    coupe
    Well... I had the 4th gear in my tranny go in september and got the tranny re biult. I also wound up getting a new sprung clutchmasters 4xoo clutch and flywheel (like stage 4) because i have a turbo.. Only have athousand miles on the clutch right now...i Recently installed the em1 cmc and did the cdv delete in the past 2 weeks.. The last couple of days i have been hearing that "groaning" coming out of first gear. Kind of like one of the videos And then i read this haha... Its been real cold out here the last couple of days i was hoping (wishful thinking) it was that at first because it kind of seems to get better as i drive it for a little.. But i dont think so. I hope i didnt mess anything up with the new cmc and cdv delete.. Im gonna try to adjust the clutch pedal differently.. But i dont know.. Aftermarket clutch and the same problem??? I hope not!!!!
  16. Nomar06
    7,418
    Charlotte, NC
    Vehicle Model:
    Fiesta ST (FiST)
    Body Style:
    hatch
    Ever since I posted about my noise it seemed to go away. The temps went up at the same time. Don't think there is a corralTion there.
    Since there was no noise for a couple days I didn't take the car it to my buddy at the dealership. In the last two day the noise is back but not as often. The temps did drop again....
    Mikeorock likes this.
  17. Darkout
    • Supporting Member
    Darkout Supporting Member
    1,107
    Cocoa, FL
    Vehicle Model:
    Body Style:
    My slave to fork arm connection is clacking now intermittent so I think it's just needs grease but it makes it feel like the pedal drops to the floor the last 1/4-1/2 inch after full disengagement. This is different than the pedal spring pop as I got under the car while someone actuated the clutch. Very hard to pinpoint so I'll be checking it out this weekend.
  18. Mikeorock
    424
    queens, ny
    Vehicle Model:
    civic si
    Body Style:
    coupe
    Good to know though.. Where do you have to put the grease? On the tip of the slave Piston that engages the fork arm? Or inside the slave piston?
  19. Mikeorock
    424
    queens, ny
    Vehicle Model:
    civic si
    Body Style:
    coupe
    Yea.. Never heard of a clutch making noise because of cold weather haha..
  20. stilletto
    stilletto Well-Known Member
    1,521
    Chicago, IL
    Vehicle Model:
    Volkswagen Golf GTI
    Dunno' about Hondas, never happened in my FA5, but my clutch fork and throw out bearing make terrible noises when cold while driving my previous WRX.
    PainlessCandy and Mikeorock like this.
Share This Page
