Does your Si burn oil?
Discussion in 'Mechanical Problems & Technical Chat' started by WhiteFG4, Jun 12, 2012.
  1. Yes
    43 vote(s)
    53.8%
  2. No
    37 vote(s)
    46.3%
  1. jasonandre
    jasonandre Deal with it
    2,607
    Alexandria, VA
    Service Bulletin 12-069, October 23, 2012
    Excessive Engine Oil Consumption
    Applies To:
    2012 Civic Si 2-Door – From VIN 2HGFG4A...H700001 thru 2HGFG4A...H703398
    2012 Civic Si 4-Door – From VIN 2HGFB6E...H700001 thru 2HGFB6E...H703802
    SYMPTOM
    The engine oil level is low on the dipstick, and the low
    oil pressure indicator may come on.
    CORRECTIVE ACTION
    Replace all the engine pistons and the piston rings.
    Dragos, webby and Monk like this.
  2. webby
    • 2019 Toys For Tots
    webby Administrator
    50,574
    thank you for the info Jason. I'm going to put this info into post 1, and the other burning oil thread.
  3. Freddiii
    Freddiii Well-Known Member
    1,251
    Brooklyn, NY
    Vehicle Model:
    Body Style:
    Great... :/ that's me. I'm H701135 in my si sedan. I knew I wasn't bugging. I'm surprised the low oil hasn't flashed yet its been 3000 miles. This sucks.
  4. scottwhi1
    scottwhi1 Well-Known Member
    178
    Vehicle Model:
    Si
    Body Style:
    sedan
    So if your vin number is in that list. You get your pistons and rings replaced? Or do you have to do the oil consumption test? And will having the reflash void this?
    Sent from my MB865 using Tapatalk
  5. jasonandre
    2,607
    Alexandria, VA
    The bulletin does not reference any prerequisites other than "The engine oil level is low on the dipstick, and the low oil pressure indicator may come on."
  6. Freddiii
    1,251
    Brooklyn, NY
    Vehicle Model:
    Body Style:
    My dealership hasn't got the bulletin yet.
  7. tacthecat
    tacthecat Well-Known Member
    212
    Cheshire, MA - USA
    Vehicle Model:
    2012 Si
    Body Style:
    Our Si Sedan is ...1137 and we're not having an issue at 5400 miles. Wonder if it's an assembly problem - we'll probably never know.
    Hope yours is "cured" shortly.
  8. Freddiii
    1,251
    Brooklyn, NY
    Vehicle Model:
    Body Style:
    I'm a lil scared if I do this. Wonder if the car will be the same...
    I'm almost at 15000 miles. Had in oil change jus before sept. will be checking the oil level this weekend. Maybe the consumption stopped.
  9. webby
    webby Administrator
    50,574
    I believe three users here have already had this work done. They all seem happy.
    Freddiii likes this.
  10. Spider210
    Spider210 Well-Known Member
    60
    So my si vin fits in this bulletin and they just completed my test. My so not burning oil this last month. Should I bring it back?
  11. Monk
    Monk Well-Known Member
    4,218
    SW Virginia
    Vehicle Model:
    2012 Civic EX
    Body Style:
    Coupe FG3:ASM
    Does it also meet this standard?
    webby likes this.
  12. jasonandre
    2,607
    Alexandria, VA
    Exactly. The bulletin is simply a notice to Honda technicians on how to handle the issue. If your car isn't consuming excessive oil, then please disregard the bulletin...even if your car falls into the range of cars that qualify.
    webby likes this.
  13. skyfox23
    skyfox23 Well-Known Member
    272
    Thank God. Keeping fingers crossed mine stays the same as it has, been almost 2K miles since I changed factory fill and it's been at the full mark every time I've checked it :)
    webby likes this.
  14. WhiteFG4
    WhiteFG4 Well-Known Member
    534
    Arizona
    Vehicle Model:
    Civic si
    Body Style:
    So after my pistons and rings were replaced, I drove it for about 1000 miles and didn't have any oil loss. Although they filled it with 10w-20 not the recommended 0w-20. After this 1000 miles they did a complimemtary oil change to check it and make sure everything was good. They filled me up with 0w-20 and I haven't been able to drive it much (I'm currently out of town for work). If I notice anything I'll be sure to comment and let my 9thcivic friends know.
    webby likes this.
  15. webby
    webby Administrator
    50,574
    Thanks for the update
  16. Freddiii
    1,251
    Brooklyn, NY
    Vehicle Model:
    Body Style:
    So my i-mid says oil 20% but dipstick is about 1/4 above the bottom dot. Is this normal for the 3000 miles since my last oil change.
  17. webby
    webby Administrator
    50,574
    I believe the top to bottom holes on the dipstick equal 1 quart. So you've used ~3/4 of a quart in 3k miles. Some users were using over a quart in a 1k miles. You wouldn't be a candidate for the engine work.
  18. Freddiii
    1,251
    Brooklyn, NY
    Vehicle Model:
    Body Style:
    K so that means my consumption went down cuz before I had to add a quart by 2000 miles or less.
  19. Dragos
    Dragos Well-Known Member
    799
    Ottawa, Ontario, Canada
    Vehicle Model:
    Si
    Body Style:
    4 Door Sedan
    I would do it, if it is a problem I do not think it will go away. Obviously go to a serious dealership with senior mechanics but in the end it is engine work that is routine for an experienced mechanic.
  20. Spider210
    60
    I used 1.5 quarts of oil between 1800-3500miles on OD now I'm at 4950 miles. I've had the car for a year now. The thing is all my driving is short trips and it doesn't burn oil unless I drive excess 200miles + in one trip. My job is less then 1 mile away. Them doing the oil consumption test over the last 2 months I was lucky to put on 600miles probably about 450 but still. On the times when I did drive few hundred miles it burnt half a quart at least. I just don't wanna be stuck with a lemon
Share This Page
