Wheel Fitment Charts!
Here's 18x9.5 +23 MB Battles tires tucked under slight rolled fender
Fronts: 18x9.5 +23 205/40/18 w/ -3.2 camber
Rears 18x9.5 +23 225/35/18 w/ -5.7 cameber
Rubbing fronts: no rear: slight rim rubbing on fender on driveways
DID you plasti dip or vinyl wrap front grill parts? If you dipped, was it hard to do the bottom chrome piece?
I plasti dipped it. for the grill and the bottom trim I just removed them. The grill was easy, the bottom trim kinda takes a little bit of effort unclipping each clip but its pretty straight forward. just need to remove the bumper
I was hoping to do it without the bumper removal with dip. You should dip the back chrome strip as well...IMO
i already mounted my ENKIE RPF1 but can't upload it because the picture is too large ??? took the pics from samsung galaxy S4 How can i upload it ? crop the picture ?
What resolution is it? Can you resize it to 50% or 75% on the phone?
It's not really based on max res, but max file size. Try to keep the pic under 2mb. Or you can cut the pic size to 50%, maybe a bit less.
20130716_190752.jpg I resize it using Paint hehe , So RPF1 ( obviously ) 17x9 +35 wrapped with falken zeix-612 225/45/17
No rubbing still on stock suspension
Might use H&R Springs or if got lucky Megan Coils By the end of august
I painted the side of the rotor just to cover some dirty rust
sorry im no good speaking english hehe
17x9.5 ET18 all around with 205/40/17
no rubbing in front, except when wheels turned to the max and moving
minor Wheel rubb in the fender on really big bumps
front and rear fender rolled, front fender pulled just a bit
Lot of pics
